![]() Drives: 2007 toyota yaris Join Date: Jul 2014
The vibration is worse at higher speed, come and goes. any ideas
Not quite a noob
Wheel balance is first on my mind
やりすぎだ~
![]() Instructions not clear enough. Penis is now stuck. Please advise.
it does not feel like tire balance more off acme and go vibration
やりすぎだ~
hmmm...
Does the vibration have a corresponding sound that gets louder when going faster? Could be a bad wheel bearing
![]() ![]() ![]() Drives: 2015Yaris, Son's car, 10 Prius Join Date: May 2010
belt slipping
That might be enough miles (if you drove really hard on really bad roads) that some of the bushings in the front suspension (tie rod end bushing ?...etc.) might be worn, or the steering rack might be fried (mine was fried in my Suzuki Swift by 151k miles...with only parts of the last 20k miles on hard, horrendous roads). Don't know if those items would cause the particular vibration you are feeling.
When I've had CV joints go bad in different cars, the noise was always a clicking that might develop into a thumping if it progressed before repairing. Don't remember getting a symptom that I would classify as a vibration. However the sound always came from closer to the left or right wheel than what you seem to be describing.
wheel balance first ...then move on to other stuff if still there
vibrations
I had a similar issue a while back and just rotating and balancing the tires fix that front end vibrations.
| Help! Can't figure out this front end clunk over bumps. | suprasb | DIY / Maintenance / Service | 9 | 07-08-2013 12:58 AM |
| MI SSK In-Cabin DIY (Golddeenoh) | BEEF | DIY / Maintenance / Service | 5 | 03-26-2013 01:19 PM |
| Question about the new 2010 yaris front end differences? | YarisSedan | Cosmetic Modifications (Exterior/Interior) | 4 | 06-12-2010 02:27 PM |
| 2008 Yaris 5000 km noise in front end!! help! | Jen | General Yaris / Vitz Discussion | 3 | 08-26-2009 08:29 PM |
| Front bra for S model Sedan? | N9QGS | DIY / Maintenance / Service | 2 | 06-27-2009 08:51 PM |
