Old 08-02-2014, 10:03 AM   #11
KKevin
Drives: Yaris 5D 1.3L M
Originally Posted by trini_per4mance View Post
So I finally hit 500,000 miles on my Yaris on Sunday 26th May @ 9.24pm. The car still runs perfect. Absolutely no issues with it whatsoever except with my clutch. I change out my original clutch after 400,000 miles and installed an ACT 4 puck ceramic disc with a heavy duty p/plate. After one year of running the car, I starting having shifting issues. Initially I thought the slave cylinder was giving up and after replacing it and still having the same issues, I thought the p/plate gave out, so I went ahead and bought another ACT 4 puck ceramic disc and a heavy duty p/plate.But when I dropped the gearbox, I realized that it wasn't the disc or the p/plate, but the flywheel. It was worn down a lot and the disc wasn't barely grabbing onto it. And because I couldn't afford any downtime, I installed the 2nd new ACT clutch kit with the worn flywheel. The clutch bites but not at fast as it should at high rpms. So I can't shift fast when I'm running out my rpm. I need to replace the flywheel and install a carbon/kevlar disc and heavy duty p/plate. Oh, and my water pump pulley is so badly worn from the the back of the belt running on it, that it actually has a groove in the pulley and is cutting that new belt that I recently installed. So I already have the new pulley to swap out.
Parts that are still working properly:
1. All Sensors (Oxygen, Crank, Cam, Knock, Coolant Temp, Oil Press)
2. A/C Compressor
3. Electric Power Steering
4. Fuel Pump & Injectors
5. Ignition Coils
6. Radiator
7. Brake Booster, Master & Slave Cylinder, Rotors and Drums
8. Throttle Body
9. Engine
10. Manual Transmission
Here's a list of repairs that I've done on my Yaris so far:
1. Struts & Shocks @ 153,000 miles on 9/7/08
2. Alternator @ 323,000 miles on 4/15/09
3. F&R Brake Pads and Shoes ONLY @ 400,000 miles on 2/21/10 (First and ONLY brake job)
4. Driver's Side Rear Hub Assembly @ 435,000 miles on 2/19/11
5. Clutch @ 448,000 miles on 9/3/11 (First clutch job)
6. Backup Switch @ 448,000 miles on 9/8/11
7. Sway Bar End Links @ 451,000 miles on 11/2/11
8. Passenger's Side Rear Hub Assembly @ 457,000 miles on 1/13/12
9. Oxygen Sensors @ 459,000 miles on 2/8/12
10. Alternator @ 467,000 miles on 5/26/12
11. Clutch Slave Cylinder @ 468,000 miles on 6/14/12 (Didn't need replacing. It was the flywheel that was worn)
12. Starter @ 469,000 miles on 6/25/12
13. Clutch @ 474,000 miles on 9/2/12
14. Fan Motor @ 479,000 miles on 10/2/12
15. Fuel Filter @ 481,000 miles on 10/30/12
16. Driver's Side CV Axle @ 483,000 miles on 12/1/12
17. Fuel Pressure Regulator @ 492,000 on 3/22/13
18. Valve Cover Gasket @ 492,000 on 3/27/13
19. Water Pump & Pulley @ 502,000 on 6/18/13
20. Clutch @ 506,000 miles on 8/11/13
21. Shocks & Springs @ 515,000 on 11/23/13
List of Acessories & Mods:
1. SUS Custom 2.5" Air Intake Kit
2. eBay Exhaust Headers
3. Magnaflow Catback Exhaust System
4. Weapon-R iThrottle Controller (Best investment ever!!!)
5. Rims (From 15" to 16" to 17" and now 18")
6. Tanabe Lowering Springs (With 500k miles on them)
7. Scangauge II
8. HID's & LED's
9. Double OEM Spoiler & Lip Combo
10. Eliminated Cats
11. Magnaflow 28" Resonator
12. 1ZZ Throttle Body
13. Taylor Helix Throttle Body Spacer
14. Tein Lowering Springs
why first clutch job over 400k but second and third only last 30k? is it because aftermarket part?
KKevin is offline   Reply With Quote
2007 Yaris S 5spd Sedan doing 300,000 miles in less than 2 1/2yrs. trini_per4mance General Yaris / Vitz Discussion 100 06-08-2022 09:54 PM
Possibly purchasing a Yaris, how many miles do you go without major repairs? chriswf New YARIS Purchase Forum 31 09-15-2012 01:14 PM
So how many miles are on your Yaris? jjonrofl General Yaris / Vitz Discussion 34 12-26-2009 12:15 AM
