snubby wubba
Drives: '09 silver 5-door Join Date: Dec 2008
Antifreeze leak on intake manifold near TB
I tried searches but didn't come up with anything like my problem.
I found this antifreeze buildup on the black plastic intake manifold. Its near the throttle body. It appears that the antifreeze is slowly leaking out of the intake manifold in this area and making little stalactites. Does anybody know what this is?
Think outside of the box. |
Try to get a pressure tester and put pressure on the system. It will drip out where the leak is coming from. There's no coolant passages in the intake manifold. I work at Toyota and have never seen a leak right there. It way be leaking from above or even a pinhole spraying to there. Best bet is to apply pressure to the system and see if you have a leak and where its coming from.
Sent from my SPH-L710 using Tapatalk |
that second picture is the coolant lines for the throttle body...maybe there's a slight leak in that hose going into the throttle body. bypass those coolant lines on the block, and see if that stops it? all those do is heat the air in the throttle body for super cold weather.
Does it drip with the engine running? If not its not something that needed to be fixed ASAP.
snubby wubba
Thanks everybody. After I posted the picture I remembered spilling some coolant around there when I changed it. I haven't looked in the engine compartment too hard since I changed the coolant. I thought I sopped it up. This seems like too much stalactite material if that is the case.
I'll wipe it off when I get a chance and see if it appears again. I'll check it when its hot, I figure that creates pressure in the system. And keep my eye on the coolant level. Cool, its good to know there's no passages in the manifold. I was worrying it was seeping out of a passage through a bad seam. I'll reply to this thread if there is a leak.
![]() ![]() ![]() Drives: 2010 Yaris Sedan Join Date: Oct 2013
Too, spray bottle with water will moisten (and sometimes just remove) for easy removal of the pink/orange crusties...
2010 Yaris sedan, TRD CAT back (sport muffler only, really), OBX header (relocated front AF sensor to front pipe), OBX throttle plate spacer, K&N filter (in stock air box-for now), TRD struts and shocks, Mexico Rough Road Springs x 4, new Yota sway bar links front, slotted/drilled rotors and Maxx brakes front, Valvoline synthetic brake fluid, 3M undercoated, 16" Konig Feathers Michelin Pilot Sport AS 3 + Tires TRD rear sway bar, 4 GT Spec bars including: front strut brace 2 point, 4 point ladder brace, mid chassis brace and rear lower tie brace, rear hitch, [B]
snubby wubba
It was the radiator cap. The level started going down faster and new white spots showed up coming from the cap. I rented a pressure tester but it didn't have an adapter that fitted my cap or my radiator. I drove a long ways with the new cap and it-no-leaky :)
Thanks everybody! The overflow tank was empty, how do I know if I have a bubble in my system?
#8 | |
You will know when you open the rad cap (when cold). You won't see any liquid |
| FS feeler thread: M/I intake manifold, TB and intake! | mr_miles | Items for Sale by private party | 10 | 06-14-2014 09:37 PM |
| stock scion xa exhaust and intake manifold and others | taman86 | Items for Sale by private party | 0 | 09-27-2012 02:39 PM |
