Old 08-11-2014, 06:41 PM   #4
Originally Posted by PierreG View Post
Thanks for the info. Guess it's time to start drilling...I would assume that it would be better for me to use a relay and get the power for the lights from the battery, and power the relay off the ignition. Would that be correct?
You can either go through the giant grommet behind the battery (which comes out under the dash to the left of the steering column) or the tiny grommet above the ECM on the passenger side.
A relay is a good idea so you are not drawing current off an existing circuit (other than to power the relay coil).
My remote start DIY shows locations for ignition switched and constant power under the dash:
http://www.yarisworld.com/forums/showthread.php?t=24860
Installing Trailer Light Harness vandallen DIY / Maintenance / Service 7 06-10-2024 10:06 AM
Removing Back seat... but wiring? G-Ammo DIY / Maintenance / Service 10 04-25-2014 08:03 AM
WTB: 2006-2008 Yaris Stereo Wiring Harnesses, AUX Jack zerosktz Willing to Buy by private party 4 02-19-2011 02:41 PM
Wiring Pictures MitchEvious In Car Entertainment + Electronics (audio / video / alarm) 2 12-28-2009 11:43 AM
Wiring color code for 2008 LB? charles nelson DIY / Maintenance / Service 0 04-25-2009 03:56 PM
