Old 08-15-2014, 09:46 AM   #6
nookandcrannycar
In the old days when engines were machined with less precision it was necessary to wear a new engine in. With the precision of machining and the factory break-in that is done on new engines this is really not necessary. The process to do so used to actually documented in the owners manual.
Thanks! Then I'll probably do 3,500 and then again at 10,000. My blue Yaris (with only 20 oil changes, IIRC) has finally started to burn oil. From roughly 274k to 288k it burned 2 1/2 quarts . Some of those miles included parts of two days on I-5/CA-58/I-15/I-40/US-93/I-10 in California on two of the hottest days ever recorded for those month/numerical date combinations....and then driving through AZ, NM, and TX from El Paso through DFW to Tyler. I added 2 quarts, and then from roughly 288k to 292k, the 2007 only burned 1/4 of a quart.
Tutorial : Speaker Changing, Headlight Painting, Center Control Colour,Panel Removal hasher22 DIY / Maintenance / Service 88 03-06-2014 06:40 AM
HELP! Interior Light Color Change Seedo broke chilly79 DIY / Maintenance / Service 9 10-25-2010 09:20 AM
Converting from Custom Wheels back to stock!!! daddz07 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 09-23-2010 08:45 PM
MJ dead 90tsi Off-topic / Other Cars / Everything else Discussions 28 06-26-2009 02:20 PM
back seat KSIbucky General Yaris / Vitz Discussion 10 05-30-2006 12:54 PM
