Old 10-07-2014, 11:23 AM   #1
To remove the AC panel to gain access down there you pull of the vertical black pieces, then pull back the radio trim and then the AC panel. There is nothing down there though that will affect the door chime. I would look for modifications at the fuse panel area. The prior owner may have done something, like jumping the acc relay, so that the power outlet is on, even with the car off.
Old 10-07-2014, 11:33 AM   #2
Alpha
Drives: 09 Yaris 2D Hatchback (maroon)
I did not see anything jumping on either fuse panels under the dash. Nothing I saw at either panel was recognizable as a relay to me but saw nothing out of the ordinary other than the one wire I mentioned. Will take a look again and take a gander at the engine compartment fuse box.
Alpha is offline   Reply With Quote
Driver Side Mirror - Can This Be Replaced Easily? (Image Attached) Yarismo123 DIY / Maintenance / Service 3 10-06-2012 11:04 AM
DIY: Adding LED turn arrows to side mirrors my2sense DIY / Maintenance / Service 10 05-28-2012 03:16 AM
Front Driver Side Wheel Chirping Hard_Yaris DIY / Maintenance / Service 5 06-29-2010 05:38 PM
Are the optional airbags worth it ? avenno2g7 General Yaris / Vitz Discussion 46 12-07-2008 03:40 AM
The Driver Side River Nutzoids General Yaris / Vitz Discussion 7 12-14-2006 02:11 AM
