Old 10-07-2014, 12:29 PM   #1
The engine compartment box is unrelated, as that is only constant power circuits.
Check the ignition switch connector as well. See if anything is jumped between the wires on there. The ACC relay is actually within the fuse box, so you can't see it, but it would have been possible to bypass it, by jumping it externally.
Old 10-07-2014, 02:11 PM   #2
Alpha
Drives: 09 Yaris 2D Hatchback (maroon)
Thank you for the assist on this. Will take look at what you suggest and report back.
Alpha is offline   Reply With Quote
Driver Side Mirror - Can This Be Replaced Easily? (Image Attached) Yarismo123 DIY / Maintenance / Service 3 10-06-2012 11:04 AM
DIY: Adding LED turn arrows to side mirrors my2sense DIY / Maintenance / Service 10 05-28-2012 03:16 AM
Front Driver Side Wheel Chirping Hard_Yaris DIY / Maintenance / Service 5 06-29-2010 05:38 PM
Are the optional airbags worth it ? avenno2g7 General Yaris / Vitz Discussion 46 12-07-2008 03:40 AM
The Driver Side River Nutzoids General Yaris / Vitz Discussion 7 12-14-2006 02:11 AM
