Old 10-31-2014, 01:59 PM   #8
mitchell12
mitchell12's Avatar
Drives: 2007 yaris HB
Lubing the control arm bolts is pointless and retorqing them all the time is retarded. They are always being stretched and are getting weakened because of it. The bushing doesnt actually rotate around the bolt. Its torselastic so the metal part stays stationary and the rubber part twists around it. Lubing the bolts might make sense if it was a leaf spring bolt but for this you are wasting time and possibly weakening the bolt.
I hope you are at least tightening the bolt with the control arm in the ride height position or you are also ruining the life span on the bushing.
mitchell12 is offline   Reply With Quote
Clutch Maintenance fnkngrv DIY / Maintenance / Service 12 03-03-2017 10:42 AM
4-wheel alignment for 5000 mi. maintenance????? Yari-Chan General Yaris / Vitz Discussion 44 01-28-2011 09:00 PM
60K Mile Maintenance Pattycake DIY / Maintenance / Service 20 11-17-2009 02:34 PM
Question about required maintenance gm830 DIY / Maintenance / Service 9 11-04-2008 03:14 PM
