Old 04-13-2007, 02:10 PM   #18
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
you most definetely dont want to connect negative to positive..you gonna short ur yaris there well if those are really ground then it has power wire.. switch power wire from headlight to fog light power wire it should work..there is no way it wont work..but even if those are the ground wire and it should still work switch headlight ground to fog light ground...
- DISABLED DayTime Running Lights How To- 2007 Yaris! - Chris07LB DIY / Maintenance / Service 266 09-04-2017 03:34 AM
