View Poll Results: Dumbest thing you have done to your Yar so far
Put a CB antenna on it 1 50.00%
Put rims that look funky/gay/stupid on it 1 50.00%
wreck it 0 0%
let it sit outside in a hail storm 1 50.00%
eyelashes 0 0%
put cheap tires on 0 0%
put off doing brakes then run into something 0 0%
upgrade all performance items except brakes 0 0%
let your friend/wife/husband drive it and they bruise it 1 50.00%
other item not listed, come up with more questions in another poll on your own 0 0%
Multiple Choice Poll. Voters: 2. You may not vote on this poll
Old 11-19-2014, 03:47 PM   #3
JimKellyfan
JimKellyfan's Avatar
Drives: 2010 Yaris Sedan
I just bought an SWR meter from Radio Shack. It did not come with a cable. So, I am gonna order a cable from Amazon. So, the CB is not hooked at the moment, but will be by next week. (didn't want to hook it until I am zeroing my meter, then getting the best SWR possible. The meter is decent and will measure output as well. Too, I have to put the end on the firewire, but wanna refer the how to as well first. And lastly, the ground near my left rear tail light, I merely sanded the body, and stuck one of the two speaker wires in there for a quick simple ground. Gonna also solder an eye on the end of the 16 gauge speaker wires I am using for ground (2 together). So, mostly ready with a few tweaks. I gave notice here at Ford, and will not have a lift readily available for my use in December, that is why I did all the underneath stuff now. (I also ran a power wire in a conduit, front to back, for the trailer harness and otherwise) (Gonna have a power tap in the trunk for whatever) I will report back the SWR and the output.
2010 Yaris sedan, TRD CAT back (sport muffler only, really), OBX header (relocated front AF sensor to front pipe), OBX throttle plate spacer, K&N filter (in stock air box-for now), TRD struts and shocks, Mexico Rough Road Springs x 4, new Yota sway bar links front, slotted/drilled rotors and Maxx brakes front, Valvoline synthetic brake fluid, 3M undercoated, 16" Konig Feathers Michelin Pilot Sport AS 3 + Tires
TRD rear sway bar, 4 GT Spec bars including: front strut brace 2 point, 4 point ladder brace, mid chassis brace and rear lower tie brace, rear hitch, [B]
JimKellyfan is offline   Reply With Quote
Stubby antenna in the car wash? DebbyM46227 In Car Entertainment + Electronics (audio / video / alarm) 6 05-23-2014 08:32 PM
Replacing roof antenna. Need info on a plug. 2005vitzRS In Car Entertainment + Electronics (audio / video / alarm) 3 03-13-2014 06:49 PM
Euro Style Antenna (Small Antenna) Saity Items for Sale by private party 9 12-12-2009 09:23 PM
DIY: Installing XM Radio with SureConnect antenna adapter The Marshall DIY / Maintenance / Service 0 07-11-2009 09:57 AM
car antenna question mikenacarato In Car Entertainment + Electronics (audio / video / alarm) 6 12-12-2008 01:41 AM
