Old 11-27-2014, 06:28 PM   #6
jcboy
Drives: Sedan 07
Originally Posted by nortonfb View Post
The ethanol if you have a higher mileage vehicle may cause more dirt in the system.
It can break residue in the tank loose.
Personally, I stay away from it though it may cost a little less. I never figured it per mile
Norton
correct. the ethanol loses some power (Joules) and more expensive fuel has more additives for cleaning. the octane is actually BS for the average consumer who doesnt change the engine's compression ratio. (octane=resistance to detonation/early combustion)
Originally Posted by Yaris_Lover View Post
Speaking of gas I was wondering when you guys gas your yaris does the pump stop often? Like when you put it in and gassing then it stops without you stopping it and the tank wasn't full yet... Sorry thank you if you guys can help!!!!!
probably just a more sensitive venturi valve on the nozzle or our tanks have smaller-diameter filler necks. in most cases it doesnt signify anything wrong.
License Plate question awebb005 Cosmetic Modifications (Exterior/Interior) 5 11-11-2014 08:28 AM
Natural Gas Transportation - Why Not? Kal-El Off-topic / Other Cars / Everything else Discussions 1 03-20-2011 01:12 PM
Voltage regulator and Amperage question... cr.chango DIY / Maintenance / Service 13 11-24-2009 12:59 PM
ctrl-alt-delete question & free anti-virus question Shroomster Off-topic / Other Cars / Everything else Discussions 18 09-08-2009 03:57 AM
Amplifier Watt Question....noob question hasher22 In Car Entertainment + Electronics (audio / video / alarm) 4 09-27-2007 03:59 PM
