![]() ![]() Drives: 2012 Yaris 5dr Hatch Join Date: Oct 2014
Anyone know if 15x8 0 will fit 3rd gen?
Im trying to figure out if 15x8 0 offset will fit a third gen without rubbing. I want a nice set of wheels but im looking to maintain a daily ride. If these wont fit I guess id probably go 16x7
Those will absolutely not fit. Offset is the key. 0 will poke out like crazy and you'll be buzzing your fenders non-stop. on a 7 inch wide wheel, an offset of about +35 is about as far as you can go.
![]() ![]() Drives: 2008 Red Toyota Yaris Join Date: Mar 2011
I am running XXR 522s 15x7 +20 on my Yaris hatchback stock suspension and have no rubbing issues. I'd say that the rear fits flush or close to flush while the front sticks out slightly. 0 offset will definitely stick out further and will most likely rub.
People who run +20 and say there is no rub obviously do not :
- carry passengers and/or cargo - hit bumps and potholes - drive and high speed over road dips and rises Sent from my iPhone using Tapatalk
I daily drive the Yaris and use it to commute my family of 4 everywhere, the trunk is always full of something either groceries or stuff, it doesn't take much. The roads here aren't always pretty so there are plenty of bumps/dips/etc. I don't try to hit bumps or potholes and don't personally know anyone does does it purposely but the ones that I have gone over haven't caused any rubbing. I did list offset wrong at +20 though, it isn't and is actually +25.
+20 is probably ok on stock high though.
I've run +32 on stock height. Under high spring compression I buzzed the inside of the rear fender arch. That was with 195/50 on 16x7. Sent from my iPhone using Tapatalk
I run 15x8 +25 lowered on DF210's. Not even close to rubbing. Getting 15x9 +0 next.
#9 | |
What suspension are you running that you are not hitting your fenders? |
2ZR swap. DO IT! Ask how!
![]() ![]() ![]() Drives: Toyota Yaris 2009; 1.0 3 Cil. Join Date: Oct 2010
Running 15x8 offset 25 with 20mm spacers in the back, it rubs a bit when taking speedbumps or strange hops in the road... but thats it, all depends on what tyre you put on :)
Front 15x8 offset 25 with 195/45/15 tyre = no rub, nothing, only rear a bit.
Speedbumps suck...!
![]() ![]() ![]() ![]() Drives: 08 BB LB Join Date: Dec 2008
You also have to consider camber. Yes with factory spec camber, lowered with 15x8 +20 you'll be killing your fenders. But my 15x8 +20 wheels never rubbed, neither do my 15x7 +36 with 25mm spacers. But I was running -4° camber all around and rolled and pulled my fenders. You will HAVE to roll fenders and possibly add neg camber to get aggressive offsets to work.
Too much of car culture is people taking things too seriously and not enjoying it for what it is. |
![]() ![]() ![]() Drives: 09 5dr Yaris Join Date: Mar 2009
16x8+0 on the rear for reference
^^ How much camber were you running? And was that before you had the fenders pulled?
That was no fender work and no camber.
I'm always baffled when people running these offsets in the 20s claim they do not rub. Always baffled.
Like Thirty-Nine, I've rear rubbed with two sets of non-aggressive setups. It is impossible not to rub with these setups being talked about when under high spring compression. Sent from my iPhone using Tapatalk
Im telling you...I have zero rubbing. I run stretched tires.
Indeed, stretched tyres are the answer ;)
Speedbumps suck...!
| AFE short ram intake in 3rd Gen | DJYojimbo | Third Gen Yaris General Discussion | 10 | 12-20-2012 09:25 PM |
| July 3rd Mosport DDT Track lapping event (Sunday) -9th event of 2011, 1pm-5pm | Touge.ca | Canada | 0 | 06-23-2011 02:53 AM |
| I test drove a Yaris, Versa and FIT | CanadaCraig | New YARIS Purchase Forum | 41 | 11-29-2008 09:18 PM |
| Test drove: Yaris sedan 5spd, Fit base auto, Civic LX 2dr 5spd | Bounty Hunter | General Yaris / Vitz Discussion | 7 | 07-11-2007 07:40 AM |
