Old 01-04-2015, 12:45 PM   #10
cregirl90
Drives: 2009 Toyota Yaris Sedan
Just to verify:
The two fuses on the positive batter terminal were checked?
The 10A GAUGE and 7.5A ECU-IG fuse in the under the bottom of the dash fuse panel were checked?
The 7.5A ACC2 fuse in the two fuse, beige fuse holder assembly on the top left of the under-dash fuse panel was checked?
If all of those were checked, another thing to check is for corrosion on either or both of the battery posts.
Finally, if the fiance has access to a multimeter, I can give you some points for him to check on the ignition switch connector.
This is the fiancée speaking. Thanks so much for your help man! I've checked and pulled all fuses you have no and saw no seperation on any or blackness ect. What your normally see in a blown fuse ya know? I have a volt meter I can check the ifnition switch. Is this something I can replace?? Thanks again!!!
cregirl90 is offline   Reply With Quote
2008 Yaris Sedan Auto - $9,500 bstump Cars for Sale by private party 0 11-08-2011 04:47 PM
yaris Advance Sedan Rudeshady Central and South America 14 06-25-2007 01:50 AM
Yaris Sedan Vs. Yaris 4dr. hatch Meow General Yaris / Vitz Discussion 11 10-29-2006 02:11 PM
