Ours are 17mm, so a standard spark plug socket will not work. Instead, just get yourself and offset box wrench.
#2 | |
2ZR swap. DO IT! Ask how!
![]() ![]() ![]() Drives: Sedan 07 Join Date: Oct 2012
I know this is an old thread, but if Im correct I happen to have come across this type of socket for the first time just recently. I think it was called an open/pass through socket set. The ratchet drives it from the outside although IIRC its like a standard ratchet inside out--meaning the driver is four-sided (square) as opposed to a hexagon in the OP's pic.
| Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 08:14 PM |
| Back seats don't fold flat? | harda toenail | DIY / Maintenance / Service | 12 | 09-23-2013 05:06 PM |
| Kawasaki 750 Side by Side StreetGlow OPTX LED | fnkngrv | Off-topic / Other Cars / Everything else Discussions | 7 | 08-26-2010 08:56 PM |
| Are the optional airbags worth it ? | avenno2g7 | General Yaris / Vitz Discussion | 46 | 12-07-2008 02:40 AM |
| DIY - HID Retrofit | Violin | DIY / Maintenance / Service | 57 | 06-11-2007 06:17 PM |
