![]() ![]() Drives: 2007 Yaris sedan, red Join Date: Jan 2015
Had to pull roof rack seals off, are they just cosmetic?
They were dried up and flopping about.
I figure if anything they were allowing water underneath them and the water would sit there. Without them the water is exposed to the sun and also flows down the front or back of the car. As far as I can tell they are cosmetic. Is it crucial to replace them asap? |
Talked to a tech, will be fine. Admin can delete.
The seams under there are just glued with a few spot welds. I would replace them to protect the seam sealer from breaking down with the UV.
Thank you.
![]() ![]() ![]() ![]() Drives: 3-door hatch Join Date: Oct 2010
Just wondering if you could repeat what the tech told you.
I am always looking to stabilize my Yaris on the freeway (still looking to stick on vortex generators) But I was also wondering if taking the flat seals off and replacing them with tall air dams (about 2" or more? talll) might help keep air from "spilling over" the sides and help car track straight? |
Said there is no need to rush to put new ones on.
That was about it. |
| OEM roof rack mounting rubber pad replacement | Yai | Cosmetic Modifications (Exterior/Interior) | 3 | 12-22-2012 12:01 PM |
| Catastrophic Yakima Roof Rack Failure | Kaykogi | General Yaris / Vitz Discussion | 8 | 08-14-2012 03:59 PM |
| Yaris 2 door Hatchback Thule roof rack question | dasnake | Cosmetic Modifications (Exterior/Interior) | 5 | 03-22-2012 12:15 PM |
| Another roof rack option for Yaris! | Cosworth | General Yaris / Vitz Discussion | 6 | 08-07-2011 10:29 PM |
| Roof rack question? | Mister Z | Cosmetic Modifications (Exterior/Interior) | 11 | 04-21-2011 09:17 PM |
