Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Technical Forums > Yaris TS Talk
Old 02-02-2015, 12:41 PM   #16
sebastianroher
Drives: 2009 Toyota Yaris Hatchback
Scott, I checked the oil valve and it was surprisingly clean. I wiped it down and re-installed it. I'm going to check the crank and cam sensor tonight when I get to work. Where is that mesh filter you were talking about? I couldn't seem to locate it. There was this bolt I'm assuming, it was bolted on below the oil valve. It had an allan key head, and I stripped it out :( do you know what that is?
sebastianroher is offline   Reply With Quote
