Old 02-15-2015, 10:07 PM   #1
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
thanks man! I can understand having to street drive the car. I think when I was daily driving my car a bit over a year ago, I had -2.7 and drove 300 miles or more between events. Tires seems to wear even, it was a good compromise
Ptuning.com
Blown_xa is offline   Reply With Quote
Old 02-15-2015, 11:37 PM   #2
Ben_
Drives: 2010 Yaris Hatch
What toe setting did you run with that camber setting?
Ben_ is offline   Reply With Quote
Old 02-17-2015, 11:31 AM   #3
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
I run .05degree in per side, mostly due to road course stuff though. I was fighting stability issues during turn in. However now with aero that might change to running slight tow out, and also because Im setting up my car more for autocross.
Ptuning.com
Old 02-16-2015, 08:18 AM   #4
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
The toe setting is what will destroy daily driven tires. I know. I used to run mild camber at about 1.6° but about ⅛" toe out and the inside edge of the tires wore down. I had an alignment and set the toe to 0 and the tires wear evenly now, but turn in isn't as quick. But I also don't track my car anymore.
Old 02-16-2015, 12:43 PM   #5
Ben_
I'm thinking I'll run a track alignment and then buy tires at the junkyard. $16.50 a tire plus $5 mount and balance from my friend who works at les Schwab. I think this is a good plan but it won't happen till I wear out my current r compounds and but my 205/50/15 s for the new rims. Its good to know what I'm running right now won't be too bad on tires so I can protect my current daily tire investment
Old 02-17-2015, 05:08 PM   #6
Ben_
Received the mini wheels today, I will be posting on the aftermarket rims thread with all my different setups after the next auto x when I run my r comps. The rims came with tires that have seen better days and I was hoping to have more life in them, but I can't complain.
Will be working on getting a more aggressive alignment soon. A good time would be when I get my new struts if I have money for them. If I don't get the struts I will probably do a change between the next auto x and the one after
WTB Tokico Struts or Trade for coilovers and cash on your end Christian_Yaris Willing to Buy by private party 0 12-30-2014 12:58 AM
***2002 ECHO,Rear Apexi Coilovers to be modified to fit, Energy Sus bushings *** Hussain-Vtec Wheels, Tires and Suspension Forum sponsored by The Tire Rack 0 06-27-2012 06:55 PM
FS Finally my MB weapons with tires and Tein Coilovers! jekqmb Items for Sale by private party 37 12-05-2011 11:03 PM
FS: BC Racing Coilovers BR Series Non-Inverted FunctionSpec Items for Sale by private party 9 06-02-2010 01:34 PM
using the tops from stock struts with new trd struts? tekmoe Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 01-13-2007 11:58 AM
