Old 06-27-2012, 06:55 PM   #1
Hussain-Vtec
Hussain-Vtec's Avatar
Drives: ECHO NCP-12/2NZ-FE
Post ***2002 ECHO,Rear Apexi Coilovers to be modified to fit, Energy Sus bushings ***
Hello there Y-W members,
I Need your Help and Support to figure a way to install my rear coilovers, need
a way to fix it Because of clearance Issue between the back wheels & tires.
Apexi Coilovers SV Damper
I just buy a JDM Apexi Full Coilovers for my Echo but i have to modifie the rear
Coilovers to fit it in my TOYOTA Echo NCP12.
The Measurements Tall 19 inch, centimeters 48.3 , mm 482, 0.4826 meter.
Need to Measure the diameter to.
For the space issue need to think for for the best solutions.
Thinking of doing this and i have some other plans to i will update this thread later on.
To make a fully welded brackets actually are stout and help prevent the springs from binding under hard side loads when cornering.
or an adjustable bracket like the on below pic.
HYPER-FLEX Bushings
Energy Suspension Parts as fallow, I have them @ home & i need to get the rest parts in order to complete my full Suspension HYPER-FLEX Bushings leave you the pics.
Parts I Need to get:
Whiteline (W53299) Control arm - lower inner rear bushing.
link @ amazon site below.
http://www.amazon.com/BUSH-KIT-CONTR...+rear+bushing.
INSTALL GUIDE
http://www.whiteline.com.au/docs/ins...ides/Z5118.pdf
Ingalls Engineering 81260 Caster/Camber Adjusting Kit
Fitment Notes: FRONT - REPLACES 14MM STRUT MOUNTING BOLTS +/- 2 DEG
The idea
Link Below,
http://www.amazon.com/Ingalls-Engine...ype=automotive
Need To modified the Lower Ball Joint & Front Outer Tie Rod End Bushing for the Maximum Driving Cornering Stability, so I think keeping the OEM Ball Joint & Front Outer Tie Rod and just change the Tie Rod / Ball Joint Dust Boots, So i need to do some Measurements to replace the OEM Dust Boots rubbers with a Dust Boots Made of HYPER-FLEX™ Performance Polyurethane from Energy-Suspension.
Link For Universal Tie Rod / Ball Joint Dust Boots
http://www.energysuspensionparts.com...Dust-Boots.asp
Feel Free guys to give fresh idea,
Thank in Advance
***High-Performance Cooling System***http://honda-tech.com/showthread.php?t=3062009
***The Basics of Reading a Spark Plug***
http://honda-tech.com/showthread.php?t=3063102
ALL-TECHwire
Hussain-Vtec is offline   Reply With Quote
