Old 02-07-2015, 08:29 PM   #8
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Yea, you are correct. It is called a Toyota Service Bulletin. What Illusion said. They are issues that happen often that Toyota has made a standard fix for or a new updated part.
I figured this would have answered all your questions if you had clicked on the link and actually looked at the TSB.
*TSB addresses the complaint
*shows how many hours it takes a mechanic to replace
*What VIN number the change was made
*Old part number and New updated part number
*Then it actually shows you HOW to replace the part yourself if you wanted to try and not pay a shop to do it. It even tells you what size sockets are needed and torque specs
That is if you actually opened up the TSB and read it.
Very well said and true but not to general public you need online access for anything more that the TSB gives in description but yes it will specify exactly how to fix or resolve the issue.
Also keep in mind if we all follow the way it should be done " by the book " we would make no money as flat rate.
There is 3 ways to fix a car
The right way , the flat rate way and the wrong way lol
If the public only really have know how it works they would never take a car into any shop .
In my opinion find a place with guys that are based on hourly pay not flat rate.
I for one hate flat rate!
A day out with mechanic went wrong- Right arm problem talhahs DIY / Maintenance / Service 6 05-17-2013 05:20 PM
Toyota Dealership Mechanic Scratched one Rim YodaBird Third Gen Yaris General Discussion 20 05-17-2013 04:03 PM
Beware of the "simple" brake job tasks Yarflana DIY / Maintenance / Service 7 03-18-2013 02:26 PM
Any one in Indianapolis know of a good job for a computer tech? CtrlAltDefeat Great Lakes 15 10-28-2009 01:16 AM
