#19 |
Yea you might be doing it wrong
#20 |
![]() Drives: 2014 Yaris HB Join Date: Jul 2014
possibly, yeah i noticed right after because the other one was so much easier and actually fit
#21 |
Haha, sometimes this is all it takes to get it put together right
#22 |
Now I'm struggling with the top nut on the front. I'm using an offset wrench and hex key
#23 |
2ZR swap. DO IT! Ask how!
17mm offset wrench, 6mm (8mm?) Allen wrench. Make sure you keep the allen wrench in one position (to keep from spinning the piston) and turn the offset wrench counter-clockwise. You may want to start the nut by putting the wrenches about 15-20° apart, then squeezing them like a pair of pliers. You use the same technique for removing the sway bar links.
If you remove the wiper cowl, there is a lot more room for your hands. I've left it on the last two times, but that was only after I got a pass-through socket wrench. Be careful if you do though--there's some super sharp edges hiding under there. |
| FS: TRD struts/shocks and TRD springs | cali yaris | Items for Sale by private party | 35 | 05-04-2013 02:37 PM |
| question about springs settling | Yarflana | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 2 | 02-11-2013 07:18 AM |
| looking for 2010 3 dr springs. Or trade for a set of microimage springs | Drama | Willing to Buy by private party | 8 | 12-26-2012 03:03 AM |
| OEM/stock shocks and springs | fmicle | Items for Sale by private party | 3 | 03-23-2010 02:02 AM |
| selling my new, never used set of Tanabe DF210 lowering springs! | songa | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 1 | 03-23-2009 11:23 PM |
