Old 02-17-2015, 05:58 PM   #5
Also, do you have normal keys or the entry and start system? If you have the entry and start system, the body ECU is involved as well.
If you do not, the things I would check are:
1. 15A AM2 fuse under the bonnet
2. Check the coil packs to make sure they haven't been damaged
3. Check for +12 volts on the brown wire of the #1 coil pack with the ignition switch on, to make sure the IG2 relay is working.
Toyota yaris hatchback headlight fits on Vitz 2005? urguardian Cosmetic Modifications (Exterior/Interior) 2 09-11-2014 04:46 PM
Toyota Hybrid R Shows Its Yaris Roots MadMax General Yaris / Vitz Discussion 0 10-10-2013 06:14 PM
I have problem with the electro ventilator yaris sedan 2005 ramy DIY / Maintenance / Service 3 08-26-2013 08:08 PM
2005 Yaris noise in engine area dwoodpub General Yaris / Vitz Discussion 5 12-27-2010 06:41 PM
