#23 |
If you have a black-light it should make it glow nice and bright if it's A/C oil/dye. And yes, it sure looks like A/C oil. Look at the bottom of your A/C compressor, it's probably wet with it.
Cheers. |
| How frequently does the automatic transmission fluid need to be changed? | Hamster | DIY / Maintenance / Service | 40 | 12-15-2018 09:07 PM |
| Clutch Maintenance | fnkngrv | DIY / Maintenance / Service | 12 | 03-03-2017 10:42 AM |
| Amsopil transmission fluid two thumbs up! | Toolaholic | DIY / Maintenance / Service | 5 | 09-11-2015 11:35 AM |
| So when DOES the transmission fluid need to be changed | dutchy999 | DIY / Maintenance / Service | 12 | 09-06-2011 05:18 PM |
| Maintenance - Change Auto Trans Fluid | Linkseal | DIY / Maintenance / Service | 1 | 08-15-2006 10:57 PM |
