![]() ![]() ![]() Drives: 2007 Yaris HB 5spd Join Date: Jan 2015
HID's wont fire up
Got an '07 hb. Bought spec d projector headlights. Hooked everything up turned on headlights and xenon's wont fire up. Hooking up to stock harness. Got power to stock plug. Power at ballast single red connector. Some one help me please
How did you wire them? Many HID kits are not setup for the Yaris' switched ground to the headlights, as opposed to switched power.
Wired them modifying the wires on the harness that came with the headlights. 2 wires that are seperate with own plugs off ballast wired into wires off plug. Black for black and blue for red for low beams. Black for black and red for red on high beams. I have the feeling your gonna tell me what I did wrong and hopefully tell me the right way.
Since they don't work that is likely the case.
With the headlights, black (left) and grey (right) are the positive wires. Then, green (right) and brown (left) are switched ground wires to turn on the high beams and blue (right) and green (left) are switched grounds to turn on the low beams.
So how would i wire them up to make them work? Is it possible?
やりすぎだ~
Please post the wiring schematic (with color codes) of your SpecD projector headlights. Also, do those headlights have lighted halos as well?
They do have halos. They where pretty easy to hook up. Wired them to the small drl thats next to the stock headlight. I will also mention that I unplugged the drl module before. Didnt like having drl's. On a side note, I lived in Connecticut off and on throughout my life. Newtown and Bethel mostly.
Tried to upload some pictures from my phone but didnt work. To large of a file.
Do they make ballast that work with switched to ground?
Gray and blue low beam. Red and grey high beam on the spec d harness.
| installed some 3000k HID's | thebarber | Photo-Video-Media Gallery | 17 | 01-22-2010 09:45 AM |
| crank, fire, hesitate, crank, fire, run, gas smell | twowheels | General Yaris / Vitz Discussion | 9 | 06-25-2009 07:11 PM |
| Dash destroyed in electrical fire. | purpleminx | General Yaris / Vitz Discussion | 79 | 06-12-2009 03:53 PM |
| DRL and HID's? | dimsum69 | Cosmetic Modifications (Exterior/Interior) | 5 | 01-12-2009 03:30 PM |
| NEW HIDS 10000k!!!!!! | elsteverino889 | Cosmetic Modifications (Exterior/Interior) | 69 | 01-26-2007 12:12 PM |
