Old 03-08-2015, 05:52 AM   #2
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
I might be able to give some input.
I used to have a throttle controller, and when it acted up, it would make the car go limp. Basically what you described, pedal to the floor and barely revving up. (I also have manual). The issue at least for me, came from the throttle controller sending bad electrical signal i bet. The car would correct and relearn throttle positions after i bypass the controller. Now it may be your Throttle Position Sensor, and a possible code would be P0122, i forget what i had, but basically read throttle position low input etc.
By chance you have a Rostra cruise control? I remember a member had similiar issues because of how it plugs into the accelerator pedal.
Check out my Build thread:
Odd exhaust issue Dubdoc DIY / Maintenance / Service 6 11-17-2014 05:18 PM
Odd throttle issue mr_miles DIY / Maintenance / Service 21 11-01-2014 09:20 AM
Throttle issue. calvin0103 General Yaris / Vitz Discussion 2 01-12-2013 03:11 PM
3 Drive Throttle Contoller by NTD Sabretooth Performance Modifications 31 10-07-2010 12:12 PM
For Sale: 1ZZ Throttle Body and 0.25" aluminum wheel spacers m911gt Items for Sale by private party 6 04-25-2009 08:52 PM
