Old 04-16-2007, 08:39 PM   #11
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
ok.....
well maybe its different with canadian model..coz i just got my yaris last saturday and had check the headlight wires right away... got 2 red wire and one black and from what i know black is always ground..red is power wires..but like i said if u got 2 ground and one power the method should still work..just make sure you grab the ground wire on the fogs instaed of power wire..
good luck!!
TE=rage2;75985]dude, use CHASSIS ground to measure the 3 wires, and you'll see that it's 12V and 2 grounds. Our lights use a switched ground system, verified by Violin here as well:
http://www.yarisworld.com/forums/sho...00&postcount=3
http://www.yarisworld.com/forums/sho...4&postcount=20
100% sure it's single 12V, and 2 grounds in the headlight plug. I've also tested my circuit with 2 separate relays and it works beautifully. If you go telling people to cut the stock wires and plug them into +, they're gonna fry their car and maybe even hurt themselves.
So, if you're looking at getting a HID kit and either disabling DRL, or running HID's as DRL without affecting fog lights at all and not touching stock wiring (just the HID harness), my circuit and relay choice will allow you to do it without any problems here:
http://www.yarisworld.com/forums/sho...37&postcount=6
Relay choice here:
http://www.yarisworld.com/forums/sho...9&postcount=13
I've even got the wire colors mapped out making it simple for any DIY'er.[/QUOTE]
Toyota unveils 2007 Yaris T-Sport Concept VitzBoy General Yaris / Vitz Discussion 63 01-21-2007 04:12 PM
