Old 04-21-2015, 10:18 AM   #5
First off, a question. What size tire are you running? 185, 195, 205?
Personally, I wouldn't bother with spacers up front and just go with 10mm in the back to push the wheels outward more to line up with the track of the fronts.
At stock height, when I was running 16x7 with 195/50 tires, offset +32, I would rub under heavy passenger/cargo load on the rear passenger side. I inserted one 1/2 bolt diameter washer on each of the lower rear hub bolts to realize enough camber to eliminate that issue. With the offset you are stating, I don't see any need to introduce camber to the rear.
2012 Nissan Versa Kal-El Off-topic / Other Cars / Everything else Discussions 22 06-15-2012 04:48 PM
Newly refreshed 2011 Toyota Corolla Kal-El Off-topic / Other Cars / Everything else Discussions 23 11-27-2010 12:57 PM
