Old 04-22-2015, 03:07 PM   #1
dasnake
Drives: 2008 yaris
Yaris cargo question - need to move 60" LCD Television
I have a 2008 yaris 2 door hatchback. I need to move a used 60" LCD TV. The TV measures 55" long. Can I get it the hatch closed and still be able to drive home? I'm 5'9". I can suck it up for a few miles in terms of comfort.
I would use a measuring tape and figure out if it would fit, but i won't have access to my car until the day I have to move the used TV.
Thanks
dasnake is offline   Reply With Quote
Old 04-22-2015, 05:20 PM   #2
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
It might not fit. Here is a link of what others have tried.
Old 04-22-2015, 05:35 PM   #3
dasnake
Drives: 2008 yaris
thanks for the link. funny i read this back in 2012 when i first bot my yaris. I'll have to use tie down straps off my roof rack. where there's a will theres a way.
Old 04-23-2015, 04:28 AM   #4
Astroman
Modded Moderator
Astroman's Avatar
I fit a Vizio 60" led tv still in the box in the hatch with the hatch closed and I'm only a inch shorter than you. I may have had to duck a bit or lean forward as I'm pretty sure it was resting on the headrests. I only had a 3 mile trip home.
Old 04-23-2015, 07:14 AM   #5
dasnake
Drives: 2008 yaris
If you have a roof rack you can ratchet strap down the roof to the latch lock catch. No need to put a TV at an angle. In your case it's fine since it's properly boxed and all.
If you have a short Roof adapter use the front roof bar to hook the ratchet strap.
Old 04-23-2015, 08:04 AM   #6
Kar98
Drives: 2011 Scion tC
You could always a rent a truck for like twenty bucks an hour.
Old 04-23-2015, 12:24 PM   #7
scod4025
Drives: 12 LE 5d HB 1nz-fe Automatic
X2 on the truck
but I got a 65" TV into my 2012 still in the box it was really tight in the car if it wasn't an automatic would not have happened
scod4025 is offline   Reply With Quote
Old 04-23-2015, 07:32 PM   #8
dasnake
Drives: 2008 yaris
It fit with a moving blanket wrapped around it, and laid down flat. No problem. Drove home comfortably.
I live in manhattan, nyc. a truck rental would have cost me $60 minimum, plus countless time wasted waiting in line.
I love this car.
Old 04-24-2015, 12:11 PM   #9
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
I love this car.
Old 04-24-2015, 10:38 PM   #10
dasnake
Drives: 2008 yaris
comfortably maybe a bit of an exaggeration. It was snug, but my knees had some wiggle room.
picking up a dresser tomorrow.
Question about using 16" rims on Yaris TRDBlair Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 06-01-2014 05:09 PM
noob question: How many kms is too much for a Yaris? 7:34pm General Yaris / Vitz Discussion 6 09-09-2012 02:21 PM
Yaris 2005 custom HU question stroebs In Car Entertainment + Electronics (audio / video / alarm) 7 01-05-2011 08:30 AM
