Old 05-22-2015, 12:18 AM   #1
Caramanos2000
Drives: 2012 Yaris 5dr Hatch
Thoughts on this gear oil?
I was wondering if this oil is appropriate for my gearbox
http://www.schaefferoil.com/293a-gear-lube.html
Caramanos2000 is offline   Reply With Quote
Old 05-22-2015, 09:43 AM   #2
shepd
Drives: 2007 Yaris 5 door RS
There is no rating specified on that page. You need 75W-90. You could try contacting them to find out if that is available from them. Otherwise, any gear lube that is rated at 75W-90 will work.
Old 05-22-2015, 10:41 AM   #3
Caramanos2000
I have it in 75w-90 however it is listed as GL-5 although it specifies it is non corrosive Guess I will try it and let you guys know.
Old 05-22-2015, 09:06 PM   #4
LTHatch
Drives: 2013 Yaris Hatchback L
Please do, the claims on that page are damn good.
LTHatch is offline   Reply With Quote
Old 05-24-2015, 02:21 PM   #5
Mikastef
Drives: Yaris
do you have automatic or manual gearbox?
Mikastef is offline   Reply With Quote
Old 05-24-2015, 02:23 PM   #6
Mikastef
Drives: Yaris
if it is automatic, why don't u keep it simple (KIP) and use the oil that toyota recommends ?
Old 05-26-2015, 12:22 AM   #7
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Unless you are doing serious shifting constantly GL-5 in our transmission is a waste and can actually possibly cause issues down the road. If you have a manual transmission your best performance and happiness will come from using AMSOIL, Redline, or if not available another synth like Mobil1 or Royal Purple.
Old 05-26-2015, 12:45 AM   #8
Hershey
You don't want a GL-5 . Go with GL-4 . I found out the hard way . Toyotas prefer the GL-4 . Go with Redline or Amsoil 75w-90 GL-4 . Both are for the better . If you do , let us know your experience .
My Oil Analysis 2007 hb 5 speed 123,994 miles mark293 General Yaris / Vitz Discussion 12 02-25-2012 11:19 PM
Natural Gas Transportation - Why Not? Kal-El Off-topic / Other Cars / Everything else Discussions 1 03-20-2011 02:12 PM
Synthetic Oil Questions. Twistoffate0817 General Yaris / Vitz Discussion 19 07-15-2009 09:54 PM
Synth Blend Oils scape DIY / Maintenance / Service 7 07-12-2009 02:55 PM
