#5 | |
toyota
reopening thread!!
sup man! got question for you? would this set up work? i know you guys may not have fog but i think i found a way to keep fogs,drl,low and high beam with hid setup!!
"for canadian models...with fogs.. ...to keep drl,fogs,hid bi-xenon with high beam.. here it is u just need to cut 2 wires...headlight should have 3 wires, ground, low,and high. cut the low beam wire.. then cut the positive wire on the fogs..interconnect them (switch them 2 wire with each other)..therefore when the car is on ur fogs is running on 10v (drl). once the headlight switch is turned on that should activate fogs on 12v and ur hid ( which was interconnected w/ the fogs.which is actually the fog light. high beam is still ur high beam..... so 2 wire interconnected...drl=fogs=lowbeam, fog switch =(hid)low, then high beam remain as is.....no relay needed may need to supply a lower amp for the fogs..coz its running amp from the headlight..and fog amp should be sufficient to run the hid bi xenon." i know u mention that the headlight is running 2 ground and one power..which is kinna weird why the black on eis the power wire??? Quote:
| Is aftermarket HID kit legal (in NJ)? | Jfoofoo | Cosmetic Modifications (Exterior/Interior) | 25 | 03-19-2009 02:05 PM |
