![]() Drives: 2007 Toyota Yaris Base Sedan Join Date: Jul 2015
Thanks for the reply CTScott. I don't have a proper gauge set. What do you think my next step is? Is my only option to take it to a mechanic?
That or buy a gauge set from Harbor Freight for $35.
![]() ![]() ![]() Drives: 2009 yaris 2 door Join Date: Feb 2013
A/C system
I just finished replacing the complete system in my vw new beetle and that system had a bad compressor, the low was too high and the high was too low. ctscott is correct you need to put both gauges to see what the system is doing, the high and low side . My guess is your compressor is shot ; if your low side stays high and the high side stays low while the compressor is engaged and the radiator fan is spinning then your compressor is bad. Also at this point it seems you might have over charged the system and so you put in another variable in the mix.
| Tags |
| a/c, air conditioning, compressor, freon |
| Intake Systems Decision Maker.. | Blenjar | Performance Modifications | 25 | 09-15-2007 10:07 PM |
