![]() Drives: 2007 Toyota Yaris Sedan Join Date: Jun 2007
Thanks, everyone. None of it is real bad, so I think I'll take that advice and keep driving it. I can't tell that the clutch is slipping or anything like that, just the occasional grinding issues. I can do a few things to reduce the grinding, so I'll just take care and keep driving it. Like you all mentioned, I had seen several others that had gotten 400,000+ miles out of their clutch, so it seemed a bit early, even if I had been hard on it. I'm guessing that if it is an issue, it will probably get worse over time and it may become more apparent as to what the issue is.
Thanks again for the advice!
#2 | |
^^^^^Park your Yaris in an empty or nearly empty parking lot, sit in the driver's seat, and perform the test outlined in post #12 on the Yarisworld page I provided the link to above. Between 200,000 and 300,000 miles I thought a few times that the clutch on my blue Yaris might be 'going'. I performed the above test and learned that it wasn't. |
| Getting Rid of the infamous Clutch "Shudder" | tmontague | DIY / Maintenance / Service | 14 | 07-08-2023 01:56 PM |
| Clutch Maintenance | fnkngrv | DIY / Maintenance / Service | 12 | 03-03-2017 10:42 AM |
| Unique Smell from Air Going Through AC Blower | EddieCabael | DIY / Maintenance / Service | 30 | 01-19-2015 09:08 PM |
| need help on my 2008 yaris compress clutch | susucosp | DIY / Maintenance / Service | 0 | 05-15-2014 03:48 PM |
| Having clutch issues ? | hystria | DIY / Maintenance / Service | 10 | 08-22-2007 11:34 AM |
