![]() ![]() ![]() Drives: 2008 lowered yaris on 17's Join Date: Feb 2015
Another nother nother foglight thread
Ugh. I hate to even start another for flight thread, but I need help guys. I just purchased an unmodified fog light kit from Garm. Basically I'm just really confused on how to do the install. It seems like everyone has their own way of doing it. I want to know if I can do everything I need to do with only what is given to me in the kit. Thanks in advance!
![]() ![]() ![]() ![]() ![]() Drives: '15 Yaris SE 5MT Join Date: Jun 2014
Doesn't Toyota sell an OEM fog light kit for their cars, or has it been discontinued for the 2nd Gen Yaris? Why is the aftermarket not capable of making a true plug-and-play 'OEM' aftermarket kit? Seems sort of strange to me.
Toyota (TM) Shareholder
The kit appears to have have everything you need but it is not necessarily the easiest way to install it. Biggest problem I can see is running the wires through the firewall.
Not how I would do it. I would install it like Bairjo https://www.youtube.com/watch?v=bilhPerqVEo |
What do the connectors look like? That'll determine how you install it
![]() ![]() Drives: 2007 Toyota Yaris Hatchback Join Date: May 2006
If you got it from Garm like I did, then look up this thread and under the second post, CTScott has a set of instructions. I'm assuming its going to be the same as far as the wires and connectors.
http://www.yarisworld.com/forums/showthread.php?t=54394 It took me a couple of hours to get it done. Fairly easy. Only thing I would say would be to read through the instructions and maybe check the fuse box under the dash to see if there is fuse there or not before you start, just so you don't have to go running around for one once you connected everything. |
The kits that Garm is selling on ebay are not the same as the plug and play kits he sold on Micro Image. The lights are the same but they have generic wiring. Of course at $35 they are still a bargain.
My advise is to install the external components as described in the video by Bairjo and then use the instructions from M4one to show you your options for internal wiring. Last edited by Sirius-XM; 07-07-2015 at 07:19 PM. |
#7 | |
Pumpman
Drives: 2019 Kia Soul EV Base Join Date: Dec 2014
"I would rather loose by a mile in a car I built myself, then win by an inch in a car that was built for me." - Moog Last edited by invader166; 07-07-2015 at 04:46 AM. |
I'm thinking that maybe I bought one of the last plug and play kits Garm still had. Glad I was able to pick it up even though it was a lot more than the unmodified version. Didn't need to deal with the headache of figuring out how to install them again.
I realized that the diagrams were for the Garm's plug and play version but they are detailed enough that the OP might be able to get an idea of whats involved in the internal wiring.
I am still leaning towards getting a stalk but I might also just wire up a switch using option 1 (on/off with low beams). My biggest issue is the Sedan doesn't have that little space next to the mirror button for a small switch. |
I'm having difficulties too! Is there anyone who can help us?
There are 2 connector, red/white, and, orange/red. I think white/red goes to the battery because it goes to a 15amp fuse, and it's a thicker gauge. The other, red/orange, I imagine goes to the fusebox somewhere?
I'll post a diagram soon. |
I have all of the parts on hand to convert the kits to plug n play kits. You would have to ship me the harness and I would modify it and ship it back. If you are interested PM me.
What extra parts do I need? Is there not a way to install it using the hardware supplied, with a few extra wires and butt connectors?
The name on the box is Carway, and it's for a 2006-11 Yaris sedan. |
#14 |
Ok here's a quick drawing of the wiring. Sorry about the size, but I thought it would be easier to see.
#15 |
The problem with those type of kits is that they are not designed to be used with the OEM wiring, so to use them you have to modify the internals of the switch assembly.
| Tags |
| foglight, helpless r, install |
| Yet another Foglight install thread | 2009Toyotoad | Cosmetic Modifications (Exterior/Interior) | 23 | 02-21-2019 10:42 PM |
| PreFacelift & Facelift same foglight? | Ot_tO | Cosmetic Modifications (Exterior/Interior) | 3 | 02-19-2013 10:52 PM |
| The Official "Bambo the Yarisworld Traveler" thread (V2) | *MAD DOG* | Off-topic / Other Cars / Everything else Discussions | 528 | 06-22-2009 03:58 PM |
| Aftermarket rim thread vs official wheel guide | regal | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 1 | 04-01-2009 12:11 PM |
