#19 |
![]() Drives: 07 yaris sedan Join Date: Apr 2009
What type of inline fuse do I use with this bypass procedure? How heavy of wire?
#20 |
I'm going direct from the battery.
#21 |
The fuse should be a 40A one, like what fed the circuit originally. You still have to be very careful, as 40A of current is enough to make a damaged wire, where not all of the conductors within the wire are intact, hot enough to start a fire, before the fuse pops.
#22 | |
Embracing Curves
Drives: '14 Prius Executive Join Date: Aug 2013
![]() In fact, they use it for the automatic A/C (highly recommended to retrofit) Sadly, I did not find an affordable fan, so I had to build a controller for the stock one on my own, but it was totally worth the effort.
I drive, therefore I am. |
#23 |
![]() ![]() ![]() ![]() Drives: 2009 5-door, 5-speed Join Date: Sep 2011
If you're going straight from the battery I wouldn't mess around with wire size. Not going to cost much more to use some 8ga, and heavy-duty fuse holders are typically that size anyhow. Make sure your fuse holder is rated for 40A+ as many are only rated to 30A. Same goes for the switch, use one that is heavy duty and rated for the current. If you ever fix it correctly, let us know what happened.
Regarding PWM, it just seems weird that a little controller costs more than all that extra wiring and resistors. But I guess resistors and copper are cheap. So what if they have a habit of melting? :þ |
#24 |
Embracing Curves
The wiring you can omit is far cheaper than the semiconductors I think :D
| Passenger airbag light on making turn signals and cabin fan not blowing? | thatbryanguy | General Yaris / Vitz Discussion | 17 | 08-16-2024 10:23 AM |
| Heater fuse keeps blowing, interior fan is dead. | phyrefighterjay | DIY / Maintenance / Service | 10 | 07-19-2015 07:18 AM |
| dead fan motor | dferguson2 | General Yaris / Vitz Discussion | 10 | 07-22-2012 01:18 PM |
| blowing ear drums and poping fuses | BlueFlash | Southwest | 5 | 05-29-2007 07:10 PM |
