Old 08-04-2015, 04:25 PM   #11
Freestylin
Freestylin's Avatar
Drives: 09 Blizzard Pearl RS LB
Originally Posted by AOR 1-1 View Post
I've got some BC racing coilovers inbound for my 08 hatch, starting to look at new wheels. Current choices are either 17x9 ET25's or 17x8 ET33's. Thoughts? What would i have to do to fit these?
It depends what look are you going for. Are you looking at going the stanced route? If so, the 17x9 +25 setup will definitely poke out of the fender. The 17x8 +33 will also poke out but to a lesser degree. If you want the wheels to sit flush with the fenders then you will need a set of camber bolts / shims to dial-in some negative camber. Also, you will need to run stretched tires or do some fender rolling/pulling for clearance when going really low. Also, on most coilover setups for the Yaris, the rear will tend to not go low enough where you may need a set of shorter springs.
“On a given day, a given circumstance, you think you have a limit. And you then go for this limit and you touch this limit, and you think, 'Okay, this is the limit'. And so you touch this limit, something happens and you suddenly can go a little bit further. With your mind power, your determination, your instinct, and the experience as well, you can fly very high.” ― Ayrton Senna
Freestylin is offline   Reply With Quote
