#1 | |
![]() ![]() ![]() ![]() ![]() Drives: '15 Yaris SE 5MT Join Date: Jun 2014
#2 | |
. I followed what some others have posted and assumed that the avg mpg reading = for the life of the car and isn't able to be reset. Don't know if the '12-'14 can't be reset, or if those years are the same as the '15 . I should probably look at the owner's manual . I've never reset mine, and it shows 40.6 MPG. Others have pointed out that this gauge probably overstates because when you take your foot off the gas, etc. the gauge often goes to 99.9, and you really aren't getting 99.9 MPG during those (albeit short) periods.
#3 | |
I prefer the 'average' MPG function. When I pressed the button and held it down, the old 32.X 'average' reset to 0, and then seemed to restart from that point on - as it was less then 20mpg for the first few minutes of driving, while leaving my house and poking around my neighborhood streets in 1st/2nd gear before hitting the main road. The'average' display on mine never jumps around, and slowly either goes up or down by 0.1 (or stays the same) as you drive under different conditions. - |
#4 | |
(it would probably make sense that this is a function that also exists on the '12-'14...I just didn't know about it re only scanning the owner's manual). The display on my 'Average MPG Gauge' behaves just like your description re your 'Average MPG Gauge', and the display on my 'Instantaneous MPG Gauge' behaves just like your description re your 'Instantaneous MPG Gauge'. When other posters have mentioned the '99.9' on the 'instantaneous MPG Gauge' in various posts, they have usually done so (at least in my observation) re how the '99.9' MPG on the 'Instantaneous MPG Gauge' ends up effecting (overstating) the Average MPG reading. These past posts led me to think that the Average MPG Gauge 'Calculates' using (fully or partially) some sort of sampling of the 'Instantaneous MPG'. Those past posts from others re the effect any '99.9' instantaneous readings have on the 'Average MPG reading' could be 'all wet', so to speak .I just use the 'Average MPG Gauge' as a guide. I still do an old school written log book, and calculate each tank separately. |
#5 | |
- Last edited by Kalispel; 08-28-2015 at 02:33 PM. |
#6 | |
![]() ![]() ![]() Drives: 2011 3dr LB Polar White Join Date: Apr 2011
| 28mpg to 45mpg city/highway | Red Horse | Fuel Economy Forum | 2 | 09-07-2012 11:29 PM |
