Old 08-26-2015, 07:42 AM   #1
#30
Drives: YR
83 and 84 are codes for no comm with the Front Satellite sensor LH and RH sensors.
You mean the 2 front airbag sensors need the correct year ones?
Just a bit confused with the "satelite" term?
#30 is offline   Reply With Quote
Old 08-26-2015, 06:24 PM   #2
That's what the service manual listed, but it did not show the location. After a bit more research the "Satellite" sensors are the side impact sensors.
Old 08-27-2015, 12:43 AM   #3
#30
Drives: YR
Can the original sensors that activated the original airbags be used again? There is no damage to them or can the sensors be tested ?
Old 08-27-2015, 05:57 AM   #4
Yes - As long as the airbags and sensors have not been damaged they are reusable. Make sure that the Airbag ECU that you purchased is really the exact same part number as your original one.
Yaris AIR BAG Passenger light - explanation needed Abk911 DIY / Maintenance / Service 10 04-17-2013 12:36 PM
2008 yaris sedan airbag... Din get answer anywhere yet... Abk911 In Car Entertainment + Electronics (audio / video / alarm) 3 04-08-2013 11:33 PM
How many forum posters does it take to change a light bulb? silver_echo Off-topic / Other Cars / Everything else Discussions 25 06-27-2011 01:50 AM
