Originally Posted by Rigaud
Did I write to remove them? NO From experience with many different cars, if you keep stock shocks/struts with bump stops and you lower then you cut the same amount on the bump stop that you lowered it. No they don't mention in the instructions but don't be surprised by the harsh ride on the rear. It's common sense.
You do realize the rear bumpstops are barely 2" right? Most lowering springs drop the car roughly that amount, not to mention the drop from coilovers or bags. So essentially you are saying to remove the bumpstop. When my car was static I had the bumpstops untrimmed in the rear, and my car was lowered 4", never had any issues with bottoming out.
