Old 08-29-2015, 09:15 AM   #6
brushforhire
Drives: 07 HB YARIS, 15 JUKE, 00 TUNDR
Also make sure you use OE fluids, not a/m catch all fluids. Can't tell you how many times I have seen goofy things happen because someone used a "fits all fluids" fluid from a local parts store.
If you look at those fluids, even the ones that say they will work for WS fluid, it will say not to use it in the hybrids. That is because it does not have the same properties as the WS fluid, that the hybrids require. True WS fluid is nonconductive. I don't like compromising on stuff like this.
brushforhire is offline   Reply With Quote
Tags
coolant, flush, transmission
Red vs pink coolant question after flush tmontague DIY / Maintenance / Service 5 04-25-2017 12:17 PM
coolant flush necessary? caineroad DIY / Maintenance / Service 4 07-18-2013 11:53 AM
Do I need a transmission flush at 57K miles if 07 Yaris should last until 100k? lejulie DIY / Maintenance / Service 14 10-23-2011 08:43 PM
Problem help MickZEL DIY / Maintenance / Service 38 08-01-2011 03:52 PM
