Old 09-12-2015, 01:18 PM   #2
As long as you do it without turning the ignition on, there will not be an issue. Unplugging the battery is not a bad idea for safety's sake with the seat mounted airbags, but the SRS system is not powered unless the ignition is on.
If you intend to drive the car with the passenger seat out, you will trigger about 10 error codes for the SRS, which you will then have to manually clear, after reinstalling the seat.
2015 Yaris seat in a 2009 yaris or other seat options? Shinare DIY / Maintenance / Service 1 11-10-2014 07:32 PM
So how are you liking your 2012 & 2013 Yaris SE? The Squirrel Mafia Third Gen Yaris General Discussion 32 04-14-2014 02:30 PM
[REQUEST] Removing Front Bumper + Faulty Electric Window '04 Yaris lufcfan DIY / Maintenance / Service 0 03-03-2010 06:29 PM
