![]() ![]() ![]() ![]() Drives: Thndr cl metallic HB 3 drs '05 Join Date: Mar 2006
What I'm trying to state is:
1. Both cars ('05 and '15) have a 11 gallon tank and a 2nz-fe - 1.3l engine. 2. I can drive 435.1km (270 mi) with my '05 and 253.9km (157.7mi) with my '15 yaris. 3. My dealer says it is normal since the engine is in a break-in period, but after that it should give me a better fuel consumption. That said, is this true?
20 years... alive and kickin'!! ![]()
#2 | |
It is true that a new engine will burn a LITTLE more fuel during break-in, but the mileage numbers and range that you are reporting are very, very low. In fact they are so low that I immediately question the accuracy of the data. I am not calling you a liar, I am simply saying that these numbers have not been placed in their proper context. A car that was showing those numbers would almost certainly be displaying other signs of trouble. Yet you say it is performing normally in all other aspects, no check engine light, no rough running, etc. Correct? The only other thing I can think of that would result in the numbers you are showing without any other performance issues would be if someone was siphoning gas out of your tank. Do like Toyota suggested, track it over a few months and see. Make sure to use the exact amount of fuel added at the pump in your calculations. Don't guesstimate. P.S. If anything I would expect the 1.3 engine to be more fuel efficient than the 1.5 |
![]() ![]() ![]() ![]() Drives: 2011 Scion tC Join Date: Jul 2012
I think in the IQ the aerodynamics also come into play. Anyway I have no hard data on FE vis-à-vis 1.5 vs. 1.3, was just my gut feeling. I would think that in the same car the 1.3 would be slightly more efficient than the 1.5, all other things being equal.
#5 | |
| Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 09:14 PM |
| ***The Engine Oil Bible*** | Hussain-Vtec | Performance Modifications | 20 | 09-28-2016 03:47 PM |
| 1ND-TV engine swap | Daox | Fuel Economy Forum | 11 | 10-01-2015 03:49 PM |
| Engine noise and Oil Lamp on | bieniman | DIY / Maintenance / Service | 21 | 12-13-2010 12:47 AM |
| 195/60-15 Tires, premium and MPG | Henry G. | Fuel Economy Forum | 24 | 09-10-2009 02:42 AM |
