Old 09-29-2015, 08:45 AM   #6
ntokozo
Drives: 2007, toyota yaris 1.0
Actually it looks like the Yaris does not have the ring, like earlier Toyotas with ABS did. It looks like the rotor for the wheel speed sensor is integrated into the hub. I would definitely check the sensor and its wiring for damage to start with.
thanks Scott. I agree with you. yesterday I checked another yaris. I could not locate the rings. they must be intergrated into the hub.
Thanks a lot. now I have to check the sensor itself. would it mean I might have to change the bearings? usually the rotor is on the bearing than the hub.
ntokozo is offline   Reply With Quote
