Old 09-29-2015, 07:00 PM   #1
Cfc
Drives: 2007 Toyota Yaris
Overheating issue
A few weeks ago my 2007 Yaris started to overheat. Based on the issues I was having I changed the thermostat and water pump. I am still having the issue. The heater will not blow hot air and the car will still over heat. I can't find any leaks. I may also have air in the system. I have tried to allowing the car to run and adding coolant when the fan kicks on. Could air pockets be the cause? Any help is greatly appreciated.
Cfc is offline   Reply With Quote
Overheating Issue YanMinor DIY / Maintenance / Service 46 07-07-2018 02:09 PM
Overheating problems scumfromohio DIY / Maintenance / Service 24 04-18-2014 02:09 AM
yaris voltage issue yaris2010RS DIY / Maintenance / Service 11 12-29-2012 04:20 PM
Water Pump issue, after taking in for Recall GeneralDon7 General Yaris / Vitz Discussion 34 05-27-2012 08:04 PM
08 HB DRL Issue BruceLee Cosmetic Modifications (Exterior/Interior) 3 02-18-2012 10:59 PM
