![]() ![]() ![]() Drives: 2012 Toyota Yaris Sedan (Vios) Join Date: Dec 2015
i never saw RS parts on ebay..i think you can really find from japan or thailand..goto VIOS 1NZ CLUB on facebook..you will see them listing parts...
RS parts come from Yaris RS (Vitz RS) series... RS parts that I know of... Performance mod - RS C coded MAF sensor (stock code is E..there is big E on the sensor..now thais be using RX8 maf on 1NZ motor..yes WTF..and it works )- RS Solenoid aka vvti oil valve (i noticed RS valve has bigger gaps..im not pro about this but i installed this one) - RS coil pack (they said its more stronger, either you can use the coil pack or replace the spark plugs with higher heat range when you install stated mods above..i got the IX plugs) - RS header (looks like aftermarket headers..but i dont like used headers...so i bought Nitto header and fabricated it with Custom mid pipe) Exterior -Front grill (they have this mesh black grill) -Red RS badge -Yaris RS back bumper (not for sedan) Suspension -I saw white trimmed TRD shock and spring but im not going to put on or purchase old suspension parts.. my rpm shift smoother after 1500rpm and quicker than before..no error or misfiring etc..just like Fluxtasy said..it works.. Thais only drive japanese and german cars...yes WTF..90% of cars are toyota, honda, isuzu etc...these guys do whatever to "break system" to get better result.. |
Mr. 155 and climbing
I am very curious about what the difference is in the voltage on the coil packs. I have seriously looked into the Okada Projects Plasma Direct Coils however at %250 per coil and then needing to purchase their supporting parts I can't stomach pulling the trigger.
eh, i dont think we have to worry about that stuff here in US.
![]() the JDM coil pack is also what we use here stock. |
The Okada doesn't really net much for the investment really. On a ka20 for example with a GT2835 @ 8PSI only gains 7whp and 17tq. Of course as the boost increases you will see a larger gain but it isn't exponentially linked.
I am very intrigued by the idea of using the higher end Vitz coil packs. Wish that there was a spec sheet comparison between them and the standard coil packs. I am sure when we Dyno my newest setup we will see if it would be of any benefit to make the upgrade. Sent from my XT1575 using Tapatalk
#5 | |
feed my pet
![]() ![]() Drives: 2015 yaris Join Date: Aug 2015
racecars run 16 volt batteries a lot in the us.no danger I think of burning up your plugs ha ha.
my E85 build is completed..you can check the "E85 Motor Build II" post from perfprmance modification section..
Sent from my ASUS_Z00AD using Tapatalk
Brain: ATD E85 Timing Advance ECU Engine: 1JZ Injectors, Header, Center Pipe, K&N Drop In, E85 Injector Converter Suspension: Hankook Tires, Performance OEM replacement Shocks & Springs F: 1.5 B: 1.4, Mu Spec brake pads, Front tower & Rear sway bars, Rays nut & lock Electric: Volt Stablizer & Multi gauge obd2 Cosmetic: Toyota red emblem
![]() ![]() Drives: 1nzfe Join Date: Jan 2016
Okoda direct spark coil pack. Direct-port nitrous.
| Can the Yaris run on E85? Anybody try it? | auxmike | DIY / Maintenance / Service | 37 | 04-06-2019 07:52 PM |
| e85 kits | chancellor6869 | Performance Modifications | 6 | 01-22-2015 09:36 AM |
| DAMN! Just put E85 in my car by accident... | TheCutsman | Fuel Economy Forum | 9 | 08-12-2009 10:51 PM |
| Consumer Reports on Ethanol | Driver | General Yaris / Vitz Discussion | 6 | 09-01-2006 11:21 AM |
