Originally Posted by CrankyOldMan
Yes, if you get the xD gearbox, you need the xD axles. RagNaCat discovered that the differential is the larger one that's similar to the other 1.8L family. Not sure if they're direct swap from a Corolla or Matrix on the axle side, but the Celica and Matrix final drive ring gears go on the xD diff (and not the Yaris/xA/xB).
I just did a bit of reading and I "think" what I've found is that the Yaris transmission(C54?) AND the XD transmission(C50?) have the same gear ratios, the only difference is the final drive. The XD has a 3.94 while the Yaris has a 3.72. So in theory the XD gearbox will give you a bit more acceleration.
I'm still unsure if the Yaris Tsport has a 5 or 6 speed though, the Internet has conflicting information...
