Old 01-03-2016, 09:29 PM   #3
f10167
Drives: 2008 Yaris
Hi tmontague,
I just installed the 211vh and got everything working except the parking light before I saw your post tonight. Just need to double check with you before I attempt to fix the issue with a paper clip. Did you un-tap the white wire (H1/10) from the headlight switch connector and then used a paper clip to ground it directly from the back of the (H1/10) pin hole to the back of H1/3 pin hole on the viper module connector? If that's the case then I will try to fix it the way you did.
Thanks you!
f10167 is offline   Reply With Quote
2014 Keyless Entry Install Question GMRelkin DIY / Maintenance / Service 4 03-09-2017 11:26 PM
keyless entry issues azamora General Yaris / Vitz Discussion 0 10-29-2013 08:29 PM
Keyless Entry Remotes are dead... now what? Zanutto General Yaris / Vitz Discussion 7 01-11-2012 05:17 AM
Keyless Entry BLKYRSSDN In Car Entertainment + Electronics (audio / video / alarm) 44 09-16-2007 10:27 PM
DIY KEYLESS ENTRY on Power Liftback? TC-LIFTBACK DIY / Maintenance / Service 0 08-23-2006 09:57 AM
