![]() ![]() ![]() ![]() ![]() Drives: 2016 SE Join Date: Nov 2015
Tire pressures and TPMS set
I was sure that the dealer blew off the mismatched front/ rear tire pressures on the SE ...
... because I've bought new cars before where the pressures were WWAAYY off !!! I was wrong. They were within 1/2 psi at all 4 corners ![]() With a nice, new digital gauge (<$10 at Kragens) - not a crappy, 45 year old, grease monkey plunger type I set 'em all 1 psi high and successfully reset the TPMS with the button under the dash. Not to be a jerk my experience has been the huge majority of drivers don't understand that the correct pressures are obtained from the door sill sticker -- not from the tire.![]()
I wonder if that only applies to stock wheels/tires?
#3 | |
![]() Drives: Toyota Vitz Join Date: Oct 2015
![]() ![]() ![]() Drives: 2007 Yaris Sedan Join Date: Apr 2009
On my 2007 the label is on the front drivers door frame.
![]() ![]() ![]() ![]() ![]() Drives: '15 Yaris SE 5MT Join Date: Jun 2014
I just do 33 PSI (cold pressure) front/back.
Yaris Hybrid Limited 2015
Drives: yaris Hybrid limited 2015 Join Date: Mar 2012
And on the new yaris the sticker is in the glove compartment almost impossible to read without getting a neck injury.
Tip Take a photo with the phone of the sticker, it makes things much easier. |
| TPMS in Spare? | Amdkt7 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 9 | 05-02-2014 08:23 PM |
| NITROGEN GAS TIRE FILL: WORTH IT? | EjDaPogi | Middle East | 15 | 03-20-2011 02:06 AM |
| DIY - - -TPMS work around | rningonfumes | DIY / Maintenance / Service | 6 | 03-03-2011 08:11 PM |
