Old 02-12-2016, 09:31 PM   #40
Pern
Drives: Yaris LE 2014
Go purchase Toyota WS fluid plus one more court than your car will hold.
1. Drain the pan.
2. Refill the pan with exactly the same amount you drained.
3. Locate and remove the fluid return line from cooler to transmission.
3. Remove it and drain into graduated container.
4. Start the car, drain out the balance of the fluid as you add the new fluid.
5. Reconnect the return line, top off the fluid to proper level.
(As an added benifit you can also change the filter if the fluid is really dirty and burnt).
This will get most of the fluid out of the car cost effectively.
Pern is offline   Reply With Quote
Tags
atf ws, transmission fluid, transmission oil, yaris
enobmort42 - Photo-Scavenger Hunt! enobmort42 Photo-Video-Media Gallery 9 03-05-2009 10:52 PM
CtrlAltDefeat - Photo-Scavenger Hunt CtrlAltDefeat Photo-Video-Media Gallery 0 03-04-2009 02:14 AM
YAR1S - Photo Scavenger Hunt! YAR1S Photo-Video-Media Gallery 4 03-02-2009 07:44 PM
Arkhangel - Photo-Scavenger Hunt Arkhangel Photo-Video-Media Gallery 0 03-01-2009 02:03 PM
Transmission Fluid caveatipse DIY / Maintenance / Service 2 09-15-2007 06:03 PM
