#163 |
![]() ![]() ![]() Drives: 07 HB YARIS, 15 JUKE, 00 TUNDR Join Date: Mar 2007
Congrats, man! I am so stoked to do this swap to my hatch.
#164 |
![]() ![]() Drives: 07 Yaris 3 door Join Date: Feb 2013
Man that's an awesome write up, Congrats!
I'm also in the process of trying to find a 2ZRFE for a swap. I'd like to find a salvage car, but looks like everything is around $2500 for an 08 or 09, plus all the fees associated from buying from CoParts. I can find engines all day long ranging from $700 to $1500. But of course, they have been stripped of all accessories like alternator, ac compressor flywheel, throttle body, wiring, etc. Just gotta be patience. Maybe something will pop up on Craigslist soon. |
#165 |
Can you image a forced induction 2ZRFE in a Yaris?
They are getting 230ish HP out of Turbo'ed Corrollas, conservative tune. |
#166 | |
No doubt the full engine would be ideal, but if that's not to be found just take some time and gather parts over a couple months. How the heck are they getting 230hp out of this engine but the 1nz it tough to get more than 135 hp off of a conservative tune? Is it an easier to manage ecu or what?
#167 | |
Check out this website on the turbos. http://www.turbokits.com/Toyota/Coro...urbo_Kit/1972/ |
#168 |
Data doesn't lie
Drives: That Scrappy 2zrVios Join Date: Oct 2014
The trick to finding everything you need is being super polite and asking for help with finding a complete engine still assembled. I had to make tons of phone calls until finally I talked to Erv at Calumet. He contacted everyone he knew in the business and a recycler 2 hours away had just pulled one out.....it was a immediate transplant into mine. Then you buy the rest from Toyota and within a few weeks you can be done!
Regarding boosting the 2zr, yes the potential is there. I have to pay off my swap loan first, then we can get crazy! |
#169 |
Data doesn't lie
I had a fellow racer test drive my car today to provide some feedback. My friend John drives a number of cars but his favorite is autocrossing his Nissan Sentra SE. He said the car feels like you get a torque jump off the line and then you feel it again at 4000rpm. He mentioned how quickly the car gets to 80mph when entering the freeway. He also noticed how the auto trans shift mapping is much better and results in quicker more solid shifts....
I have a appointment with The Smoking Tire in April for them to review the car also! |
#170 | |
![]() ![]() Drives: 2007 Toyota Yaris Join Date: Nov 2015
#171 | |
2ZR swap. DO IT! Ask how!
#172 |
Data doesn't lie
I have a spare Corolla harness, but it was cut at the fusebox end.....Ill donate it to the first person that actually starts the swap.....and you gotta be willing to do all the soldering.
On another note, I won again this weekend even though I didn't do my best... https://youtu.be/WxOtsRiVXCU |
#173 |
![]() ![]() Drives: 07 Yaris Join Date: Sep 2012
Noob question. If you are using the corolla engine, but with the Xd ECM... then aren't you only limited to the power of the Xd ECM of 126hp?
Are you planning to do any tuning? |
#174 | |
Data doesn't lie
I do have a Camcon Ex to tune my 2zr with, once the BAR certificate is affixed. |
#175 |
Welp, just got off the phone with my local yard. Looks like I got most of the swap coming for under $850. Glad I work for a dealership. :) I just got to buy some a/c lines and I'm golden. I will start a build thread shortly.
Thank you so much for posting this how to and clarifying how easy this can be to do. |
#176 |
I vote you post your build experience on her or on a new thread so us future swappers can learn as much insight as possible on the different ways to do the swap
Looking forward to your build! BTW, $850 seems ridiculously cheap, how'd you swing that?
#177 |
I managed to snag that price, by basically just building a relationship with the local yard over the past 11 years. We help them out with parts when they need them, and when I need random stuff like this, if they can cut me a break they will. This was way better than I expected though. Engine only has 65k on it.
I will probably start a new build. The plan is to provide photos from beginning to end. I have to redo my entire exhaust and that helped push me to start it sooner. I am doing the XD front brake upgrade with SS lines form Micro image also. I am hoping to get some Megan coilovers on the car while I am doing all this. |
#178 | |
Data doesn't lie
#179 |
My 2006 doesn't have abs.
Does that mean I'm limited to using the yaris transmission? Edit: also am I limited to using anything else like what harness/ecu/ecm? |
#180 |
Data doesn't lie
Without ABS you are limited to any trans with a speed sensor, that is compatible with the 2zr/1nz bell housing. Unless there is a way to install a speed sensor into the Corolla/Xd trans...
| unusual engine swap | CoryM | Performance Modifications | 26 | 10-09-2015 12:17 AM |
| ***How to Choose an Exhaust System*** | Hussain-Vtec | Performance Modifications | 16 | 03-16-2014 08:02 AM |
| engine swap | djhuddy2442 | Performance Modifications | 6 | 04-11-2013 01:05 AM |
| Boost Gets U Laid eh? Count me In | yaris2010RS | Forced Induction Forum | 128 | 02-02-2013 04:57 PM |
| Scion/Yaris engine swap | mrrock | Performance Modifications | 1 | 03-02-2011 06:56 PM |
