Old 03-12-2016, 01:24 PM   #1
Giantrabidpanda
Drives: yaris
Accidental transmission abuse
So I was going up a hill in 2nd gear in my automatic 2nd gen yaris sedan, and when I tried to put it back in D it went all the way to neutral for a split second before I put it back in D. My foot was on the gas, it rev'd pretty loud but it didn't seem to jerk like you would expect when it went back in D. No tire chirps or anything.
What I want to know: will the ECU prevent things like this from damaging the trans?
Gotta stop the accidental natural drops lol.
Giantrabidpanda is offline   Reply With Quote
Old 03-12-2016, 03:46 PM   #2
tmontague
tmontague's Avatar
You'll be fine, it was once. Just don't make it a habit and you're trans will last a long time
Old 03-13-2016, 03:46 PM   #3
Giantrabidpanda
Drives: yaris
Ok thanks. I'm still pretty worried about it, though. I was going about 25 mph at the time I wonder if that lessened the shock. I tend to be super paranoid about these things. Maybe get new transmission oil?
Old 03-13-2016, 04:33 PM   #4
tmontague
tmontague's Avatar
Meh, if you're due to a Trans oil change then go for it. If you're not then i'd say don't bother. Seriously, it hasn't done anything to your Trans. If it was shifting funny or making a noise after the fact then that' different. Toyota tranny's tend to be bomb proof
Old 03-13-2016, 07:53 PM   #5
Giantrabidpanda
Drives: yaris
Yes! Reassurance! Tell me more! Tell me its going to be OK!
Ok, Psycho Therapy forum is my next stop.
EDIT: Finally found the ATF fluid dipstick and its very purple. Is that normal for this fluid?
Old 03-14-2016, 12:40 PM   #6
jack black
jack black's Avatar
Drives: 2007 red Yaris HB AT
if so, use D all the time and don't pretend you drive a stick shift.
jack black is offline   Reply With Quote
Old 03-14-2016, 12:41 PM   #7
jack black
jack black's Avatar
picture?
how many miles?
btw, you (probably) should be fine.
Old 03-14-2016, 02:39 PM   #8
Giantrabidpanda
Drives: yaris
Yeah, definitely going to leave it in D from now on.
80k miles
Old 03-14-2016, 02:41 PM   #9
jack black
jack black's Avatar
80k miles
good time to change the fluid. the WS ATF does change to purple with time and oxidation. the newer batches don't seem to do it.
Old 03-14-2016, 03:52 PM   #10
Kar98
Drives: 2011 Scion tC
Unless you're going up, or a down a hill. Then shift down. Uphill, to prevent the transmission from bouncing back and forth between gears, and downhill, to utilize engine braking rather than riding the pedal. Depends on the kind of hill we're talking about, of course. Don't bother in Kansas, but do watch it in Colorado.
Kar98 is offline   Reply With Quote
Old 03-15-2016, 10:05 AM   #11
jack black
jack black's Avatar
of course. what kind of hills are we talking about in sacramento?
Old 03-15-2016, 11:08 AM   #12
bronsin
bronsin's Avatar
Ok thanks. I tend to be super paranoid about these things. Maybe get new transmission oil?
If the oil is for the car...no. If its for you...yes.
Old 03-15-2016, 01:18 PM   #13
Kar98
Sierra Nevada foothills.
How frequently does the automatic transmission fluid need to be changed? Hamster DIY / Maintenance / Service 40 12-15-2018 09:07 PM
My 2010 yaris is on its 4th transmission!! Help please Uzairlexus DIY / Maintenance / Service 12 07-16-2013 10:46 PM
Transmission & Reverse Twistoffate0817 DIY / Maintenance / Service 4 08-28-2012 06:50 PM
