Old 12-07-2014, 03:46 PM   #1
dihzenyo
Drives: yaris sedan
Exclamation 2nzfe 1.3 to a 1.5?
hi all,
is there a way to increase the stroke of the 2nzfe?
like switching some internals so instead of the 1.3liter 2nzfe 89 hp, swapping some internals to make it a 1.5 liter 109hp 1nzfe?
any suggestions, help, pics, prices, anything is highly appreciated!
dihzenyo is offline   Reply With Quote
Old 12-07-2014, 06:57 PM   #2
Jcp123
Drives: '00 Echo
As I understand it, it's just a longer throw in the crank? I'd like to go the other way and make a super-frugal 2NZ out of mine...
Jcp123 is offline   Reply With Quote
Old 12-07-2014, 08:10 PM   #3
With the change is displacement, you would also need to change the ECM or use a piggyback to add or remove fuel, depending on the direction that you go.
Old 12-07-2014, 10:43 PM   #4
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
are the ECMs different part numbers?
Wouldn't the MAF just read an increase in airflow and compensate anyway. I read an article of a guy with an MR-S swapping in an 1NZ from the 1ZZ and used the 1ZZ ECM and everything works fine.
Old 12-08-2014, 09:46 PM   #5
dihzenyo
Drives: yaris sedan
any documentation that this has been done?
Old 12-08-2014, 09:57 PM   #6
The ECMs are different part numbers. With a 15% difference in cylinder volume, I am not sure that the ECM could properly compensate for the air flow difference.
Old 12-09-2014, 09:33 AM   #7
Ryze268
Ryze268's Avatar
Drives: 2002 JDM Vitz 1.3
Just get a 1NZ bottom end with the crank and rods, everything else from the 2nz will work
2000 JDM Vitz [2NZ-FE Crap-otmatic] < Now Manual Conversion complete
Follow me on Instagram:
instagram.com/itzkingjustin
Ryze268 is offline   Reply With Quote
Old 12-12-2014, 01:51 PM   #8
dihzenyo
Drives: yaris sedan
its just like you swapped the entire engine from 2nz to 1nz.
Old 03-28-2016, 03:11 PM   #9
sang pengembara
sang pengembara's Avatar
Drives: Y-sedan'07-1nzfe engine swap
Originally Posted by dihzenyo View Post
hi all,
I swap the entire engine block by 1nzfe.. Nothing need to be modified.. Working well till now..
Sent from my C6903 using Tapatalk
sang pengembara is offline   Reply With Quote
performance
Vitz 1.3 litre to Vitz 1.5 RS (paddle shift) the little car that could General Yaris / Vitz Discussion 0 02-03-2012 04:51 PM
NST for 1.3 2nzfe Toy Yaris Performance Modifications 4 03-01-2010 12:03 PM
TURBO KIT for Yaris 1.3 or 1.5 Giupo Items for Sale by private party 27 01-22-2010 11:01 AM
if i am thinking about an engine swap - from 1.3 to 1.5 - please help ASHRAF Performance Modifications 15 01-03-2007 01:40 PM
